wpt Posted March 13, 2010 Posted March 13, 2010 Please, where can I find Polygon window selection? I have autocad 2009 Quote
lpseifert Posted March 13, 2010 Posted March 13, 2010 At the Select objects prompt (or similar) enter WP Quote
wpt Posted March 13, 2010 Author Posted March 13, 2010 When I entered Wpolygon or WP there was written Unknown command Quote
lpseifert Posted March 13, 2010 Posted March 13, 2010 That's because it's not a command- it's a method to select entities similar to Window or Crossing. Type at the command line... Select WP Quote
wpt Posted March 13, 2010 Author Posted March 13, 2010 That's because it's not a command- it's a method to select entities similar to Window or Crossing. Type at the command line... Select WP I undestand, I've non-english autocad that is why it doesnt work! Its not handy for use. Is there more easy way for poligon select like in photoshop? Quote
Cad64 Posted March 13, 2010 Posted March 13, 2010 What language version of Autocad are you running? Check the Help files for information about "Selection Windows" Quote
wpt Posted March 14, 2010 Author Posted March 14, 2010 Thnx! How can I copy layers in autocad, so i need to make a double of a layer. Quote
Squirltech Posted November 18, 2011 Posted November 18, 2011 Ok, I know the whole SELECT and WP thing but here's my question. (Note: I'm running LDD with ACAD 09) I want to change the layer that some LDD points are on WITHOUT selecting the surrounding entities so I use SELECT and WP, but here's the thing. I'll complete my polygon, zoom out so everything is inside my polygon, hit ENTER. It ends the command...I didn't get to pick the new layer for my LDD points? I tried it on some lines and circles as well and got the same result. I know it has to either be a setting in OPTIONS or how I am executing the command. Any thoughts?? Thanks in advance! Quote
