PALGRAVE Posted March 14, 2010 Posted March 14, 2010 I just finished a mesh model and used the hide command in model space - it seemed to work fine - however when I used the command in layout space half the drawing disappeared - what is happening? Quote
MikeScott Posted March 15, 2010 Posted March 15, 2010 You'll likely need to attach the file so that a 2010 user can download it and experience exactly what you're describing. Quote
PALGRAVE Posted March 16, 2010 Author Posted March 16, 2010 The original drawing is not required - draw a sample mesh drawing in model space and use the hide command - it should work, then create a layout, use floating layout (model) and try the hide command again. This is when things go wrong. Quote
iskalipsi Posted March 16, 2010 Posted March 16, 2010 try to post a screen shot of your mesh in model space here so we can see whats wrong... Quote
