LearningQuickly Posted March 16, 2010 Posted March 16, 2010 Hello Everyone! I am having an issue with my xref's layers once bound to my dwgs. I made a custom button that will binds all xrefs, zooms extense, purges all, audits twice, sets my LTS, then saves as. My problem is that once I bind the xrefs the layer names still have the xref-tagged layer names. Example: Layer in dwg = 09151-TitleBlock|G-ANNO-TEXT Once I bind the xref with my buttonthe layer name becomes... Layer name after button = 09151-TitleBlock$0$G-ANNO-TEXT Now if I go through my xref manager and bind/insert them individually I dont have this layer name change occur. It will just remain G-ANNO-TEXT with no reference to the xref at all. This is what I need...but I want to use my button. I was told that there is some sort of variable I can set so that my ACAD automatically bind/inserts xrefs instead of bind/bind-ing them. Any of you fine individuals happen know what that variable command is??? Thanks in advance! Quote
NBC Posted March 16, 2010 Posted March 16, 2010 try changing system variable BINDTYPE to a value of 1 Quote
LearningQuickly Posted March 16, 2010 Author Posted March 16, 2010 Thank you very much NBC. I thought I had already set that variable. This looks like it is solving my problem. Quote
