Cross sections with corridor, pipes and trenches.
I am trying to create cross sections showing a standard road corridor, pipes, and a trench around the pipe. I have a baseline alignment and profile, a pipe network, an alignment and profile that follows the pipe network. I created an offset on my road assembly for the standard trench to attach to, and in the corridor properties I set the offset to follow the alignment and profile of my pipe network.
My cross sections just show the standard road section and the pipes, not the trench that is attached to the offset. I think this is because the offset is on a different alignment than the baseline alignment.
I have also tried creating a corridor with the basic road and a second one with the just the trench. The road follows the baseline alignment and the trench follows the pipe alignment. Even when sampling both corridors, the sections only show the corridor that is attached to the parent alignment of the sample lines.
How do I get all three of these to show up in one cross section? I don't want to nor should have to do separate cross sections for my road and trench.
