Adding block / blocks at selected text / object locations. (Auto Populating?)
Guest Brian_MMC
Guest Brian_MMC
I have a hand full of different blocks that I need to show up at the justification point on some selected text. Is it possible to have the block automatically be placed to an item like this? I think anything would be better than adding them one by one around the drawing.
Currently I’m using quick select to pick out the needed text and moving them 1000’ to the right filling in the blocks and moving everything back.
Thank you for your ideas in advance.
Brian,
You could try this... not extensively tested and kinda bucolic
(defun c:test (/ str bn ss idx tobj)
 (vl-load-com)
 (setq str (getstring T "\nEnter text: ")
   bn (getstring T "\nEnter Block name: ")
   ss (ssget "X" '((0 . "*TEXT")))
   idx 0
 (if (not (tblsearch "BLOCK" bn))
     (princ (strcat "\nBlock " bn " doesn't exist in the drawing"))
 (repeat (sslength ss)
   (setq tobj (vlax-ename->vla-object (ssname ss idx)))
   (if
     (= (strcase (vlax-get-property tobj 'Textstring)) (strcase str))
       (vl-cmdf "insert" bn (vlax-get tobj 'InsertionPoint) "" "" "")
   (setq idx (1+ idx))
