How to copy a selected area of a drawing to a new drawing ??
Hi,
I want to copy selected area of a drawing to a new doc(Autocad .dwg). I tried all but unable to do so. Can anybody help me ?
Just rename (save as) the file and delete what you don't want.
KC
Or you could use the 'copyclip' command select what you want and then paste it into your new drawing. Or if you require your objects to be pasted in certain co-ordinates use the 'copybase' command.
or you can WBLOCK the parts you need to a new file
It didn't work. I'm using Autocad 2004.
what didn't work? - all the above options should be available to you with 2004. My solution has been present since at least V2.6
edit menu
copy with basepoint
Select base point with mouse
select items (anything dotted will be copied)
hit enter
open new drawing
to paste in drawing.
select point
done
That's one of the ways listed above. As said above, all will work with your version of autocad. Unless you are unable to select the items because they're in a block or on a locked layer or something?
Another possibility to consider is that the original drawing has been opened/edited in AutoCAD 2007 at some time, and has the copy bug. :cry:
:?Copy bug? I've not come across that.
Yet :).
Copy bugs? I haven't see any of those either.
I copy 'n paste almost eveyday.
Did you get copy workin'?
You would not have because you are using r2007. It is those people using earlier versions, and opening a drawing that has been saved as a lower version from 2007.
The bug disables the copying, pasting and Wblocking functions.
If that is the culprit, then one way I have found of overcoming it is to start a new drawing "From Scratch", insert the other drawing in it as an exploded block, and everything should be working as usual.
heh.. so that WASN'T just me.. Thanks for the workaround, in case I see that again.
