CadMax Posted August 21, 2008 Posted August 21, 2008 Ok this might be a simple question but it's bugging the hell out of me. I'm working on 2 screens and I would like to have my design center on the opposite of autocad. I moved it from that screen onto the autoscreen on, and now I can't move it back. When I right click the move setting is gray? Help is appreciated cause this is annoying. Quote
NBC Posted August 21, 2008 Posted August 21, 2008 sounds like you need to set system variable LOCKUI to a value of 0. that should enable you to move your design center to wherever you like. before you set that variable to 0, make a note of what it is set to before you change it, so you can revert the value back to its original setting once you have moved your design center Quote
CadMax Posted August 21, 2008 Author Posted August 21, 2008 sounds like you need to set system variable LOCKUI to a value of 0.that should enable you to move your design center to wherever you like. before you set that variable to 0, make a note of what it is set to before you change it, so you can revert the value back to its original setting once you have moved your design center Thanks it worked like a charm My work is gonna be so much easier now Quote
