Is there an easy way of finding the Target Icon of a camera when attempting to find it in a drawing (to adjust composition)
Also I couldnt find a way of hiding the cyan constraint lines that I dont really need to know the position of. Is there an option for this?
Ta:roll:
To select the camera's target:
You can hit "H" on your keyboard to bring up the "Select From Scene" dialog. Then just browse through the list until you find the "Camera01.Target", select it and then hit OK.
You can also select the Camera, right click and choose "Select Camera Target".
To turn off the camera's display cone:
With the camera selected, go to the Modify panel, under "Parameters" and uncheck the "Show Cone" box.
Note: A camera's display cone is always visible while the camera is selected, regardless of the "Show Cone" setting.
