vertical horizons Posted March 22, 2010 Posted March 22, 2010 Using the constraint command, if you align Object A with Object B, Object A stays connected. If you move Object B, & then update, Object A will reconnect with Object B. My question is... Is there a way to remove the constraint, once it has been placed on an object? Sometimes, I find that I need to add a component to the drawing, and it needs to go in between two objects that I constrained earlier. I have sometimes had to delete one of the items and re-insert it to get the constraint to go away. Quote
JD Mather Posted March 22, 2010 Posted March 22, 2010 In ipt right mouse button Show Constraints. Select constraint to be deleted and right mouse button Delete. In iam right mouse button on constraint in browser and Delete. Quote
