cms370 Posted March 23, 2010 Posted March 23, 2010 I have created a surface from a corridor. After the surface was created further inspection showed that there are ridges within the created TIN surface. Please see the attached .pdf. Any idea why this would be happening? The corridor itself appears to be smooth and natural. I have tried manually editing the created TIN (add/delete) lines but that just results in missing elements. Any ideas? Corridor Surface2.pdf Quote
cms370 Posted March 23, 2010 Author Posted March 23, 2010 Ok...looks like I was wrong. I was able to adjust the frequency of the assembly (In prospector: Corridor -> Corridor Properties -> Parameters -> Frequency -> Click "No" to all and assign a uniform distance for each parameter). This makes the corridor much more "cleaner" which results in a better looking TIN. Quote
