cms370 Posted March 23, 2010 Posted March 23, 2010 Is it possible to convert a .DXF Topo map (comprised of 3D Polylines) into a Surface within C3D? My current thoughts are this: Explode the 3D Polylines into single points. Create a TIN surface from the individual points. Apply Breaklines/Boundaries as necessary. ...but I would think there would already be an easier way to do this?!!? Quote
alanjt Posted March 23, 2010 Posted March 23, 2010 Is it possible to convert a .DXF Topo map (comprised of 3D Polylines) into a Surface within C3D? My current thoughts are this: Explode the 3D Polylines into single points. Create a TIN surface from the individual points. Apply Breaklines/Boundaries as necessary. ...but I would think there would already be an easier way to do this?!!? You can create a surface with Drawing Objects, which will allow you to select PLines. Quote
cms370 Posted March 23, 2010 Author Posted March 23, 2010 I have tried using the "Drawing Objects" located under surfaces. Using both Line and 3D Faces results in C3D stating that "Select Objects: 0 Found".... Also, it appears that the closed polyline are only polylines and not 3D polylines. Rotating the Topo map does show that the map has height... Quote
sinc Posted March 23, 2010 Posted March 23, 2010 Did you try exploding the polylines and adding them as "Lines"? Quote
cms370 Posted March 24, 2010 Author Posted March 24, 2010 Yes, I have also tried exploding the polylines. C3D just crashes...the DXF is quite large. Is there a threshold on the "explode" command in which it will no longer work? Quote
alanjt Posted March 24, 2010 Posted March 24, 2010 Yes, I have also tried exploding the polylines. C3D just crashes...the DXF is quite large. Is there a threshold on the "explode" command in which it will no longer work? Turn the Highlight variable off and try selecting them again. Quote
cms370 Posted March 24, 2010 Author Posted March 24, 2010 Help me out here (new user here...). What is the Highlight variable? Quote
BIGAL Posted March 25, 2010 Posted March 25, 2010 At a guess higlight is when you pick objects it changes then to dashed etc requiring a complete redraw if pick all objects Quote
