MichaelBrenden Posted March 23, 2010 Posted March 23, 2010 How can I make the dimension lines and text brighter? In 2D or 3D wireframe, the dimension style and text is bright white, as it should be. It's all on a DIM layer whose color is bright white. But when I switch to the "realistic" VisualStyle, the dimension lines and text change to nearly invisible (dark, dark grey on black background). I'd prefer to keep the black background... Quote
ReMark Posted March 23, 2010 Posted March 23, 2010 I think most people don't use Realistic visual style intending to show dimensions. I know I don't. It's more of a "pretty picture" thing if you know what I mean. After all, the objects should really be fully dimensioned in other parts of the overall drawing or project. Quote
MichaelBrenden Posted March 23, 2010 Author Posted March 23, 2010 ehhhhok, think I figured out what was going on..... Somehow I'd set the global 3D Visualization Material property to anodized black aluminum, which appears as only a few shades above black. Then I drew some dimensions with this property set. I don't see how the 3D Vis. Material property can be changed, however, for existing dimensions...so once they're drawn wrong, that's it.... Quote
MichaelBrenden Posted March 23, 2010 Author Posted March 23, 2010 ReMark, agreed. Thanks. I was just quickly throwing down some floating viewports in a paper layout to experiment with and noticed the 'dims too dark' problem... Yet the apparent inability to change 3D Vis. Material property once set for a Dimension is irksome. now back to studying the behemoth that is AutoCAD... Quote
ReMark Posted March 23, 2010 Posted March 23, 2010 Thanks for the update Michael. I don't get much call for producing anything in realistic visual style although it is fun to play with it. Quote
