klpocska Posted March 24, 2010 Posted March 24, 2010 How to rotate leader's text with VBA, and how to set the rotation angle in the model space (by clicking)? Public Sub Leader() Dim dblPoints(5) As Double Dim varStartPoint As Variant Dim varEndPoint As Variant Dim intLeaderType As Integer Dim objAcadLeader As AcadLeader Dim objAcadMtext As AcadMText Dim strMtext As String Dim intI As Integer intLeaderType = acLineWithArrow varStartPoint = ThisDrawing.Utility.GetPoint(, "Select leader start point: ") varEndPoint = ThisDrawing.Utility.GetPoint(varStartPoint, "Select leader end point: ") For intI = 0 To 2 dblPoints(intI) = varStartPoint(intI) dblPoints(intI + 3) = varEndPoint(intI) Next strMtext = InputBox("Notes:", "Leader Notes") If strMtext = "" Then Exit Sub ' Create the text for the leader Set objAcadMtext = ThisDrawing.ModelSpace.AddMText(varEndPoint, Len(strMtext) * ThisDrawing.GetVariable("dimscale"), strMtext) ' Flip the alignment direction of the text If varEndPoint(0) > varStartPoint(0) Then objAcadMtext.AttachmentPoint = acAttachmentPointMiddleLeft Else objAcadMtext.AttachmentPoint = acAttachmentPointMiddleRight End If objAcadMtext.InsertionPoint = varEndPoint 'Create the leader object Set objAcadLeader = ThisDrawing.ModelSpace.AddLeader(dblPoints, objAcadMtext, intLeaderType) objAcadLeader.Update End Sub Quote
fixo Posted March 25, 2010 Posted March 25, 2010 Try this Option Explicit Public Sub Leader() Dim Util As AcadUtility Dim dblPoints(5) As Double Dim varStartPoint As Variant Dim varEndPoint As Variant Dim intLeaderType As Integer Dim objAcadLeader As AcadLeader Dim objAcadMtext As AcadMText Dim strMtext As String Dim intI As Integer Dim ang As Double ' Get utility object Set Util = ThisDrawing.Utility intLeaderType = acLineWithArrow varStartPoint = ThisDrawing.Utility.GetPoint(, "Select leader start point: ") varEndPoint = ThisDrawing.Utility.GetPoint(varStartPoint, "Select leader end point: ") For intI = 0 To 2 dblPoints(intI) = varStartPoint(intI) dblPoints(intI + 3) = varEndPoint(intI) Next strMtext = InputBox("Notes:", "Leader Notes") If strMtext = "" Then Exit Sub ' Create the text for the leader Set objAcadMtext = ThisDrawing.ModelSpace.AddMText(varEndPoint, Len(strMtext) * ThisDrawing.GetVariable("dimscale"), strMtext) ' Flip the alignment direction of the text If varEndPoint(0) > varStartPoint(0) Then objAcadMtext.AttachmentPoint = acAttachmentPointMiddleLeft Else objAcadMtext.AttachmentPoint = acAttachmentPointMiddleRight End If objAcadMtext.InsertionPoint = varEndPoint 'Create the leader object Set objAcadLeader = ThisDrawing.ModelSpace.AddLeader(dblPoints, objAcadMtext, intLeaderType) ' Get angle ang = Util.GetAngle(varEndPoint, vbCrLf & "Specify direction >>") ' Rotate mtext objAcadMtext.Rotation = ang objAcadLeader.Update End Sub ~'J'~ Quote
iyant Posted March 6, 2014 Posted March 6, 2014 i have this code, and i wanna to rotated text. maybe anyone can help me. thanks Sub Xxxx() Dim ACAD As AcadApplication Dim txObj As acadText Dim ws As Range Dim CrdNo(0 To 2) As Double Dim TxNo As String Dim hNo As Double Dim LastRow As Double Dim i As Integer Dim j As Integer Dim k As Integer Set ACAD = GetObject(, "AutoCAD.Application") Set ws = Worksheets("NUM").Cells LastRow = ws(Rows.Count, 20).End(xlUp).Row hNo = 0.3 For i = 2 To LastRow j = 20 CrdNo(0) = ws(i, j): CrdNo(1) = ws(i, j + 1): CrdNo(2) = "0" TxNo = ws(i, j) Set txObj = ACAD.ActiveDocument.ModelSpace.AddText(TxNo, CrdNo, hNo) Next i End Sub Quote
