how do i make a spline on a shaft with inventor
with using of the design acclerator i couldnt use the following dialog box to make a spline on a shaft using inventor
Thank you very much for help....
I believe you need to pick your refernces. You need a direction(reference2) to start the groove from. see if that works out.
