fohlmann Posted March 24, 2010 Posted March 24, 2010 I am a self taught novice in Autocad LT 2004, which I use to edit factory layouts. I simply want to add a dimension between two points and it is usually very straight forward. But on this particulary layout, the dimension disappears when I click to set it. The same goes when i try to draw a simple line or anything really. I can see it while i draw but when I click to finish it disappears. Any ideas? /Brian Quote
ReMark Posted March 24, 2010 Posted March 24, 2010 You're drawing on a layer that is turned off. Quote
fohlmann Posted March 24, 2010 Author Posted March 24, 2010 And a million lines and dimensions appeared... I should have registered here much sooner - cheers! Quote
ReMark Posted March 24, 2010 Posted March 24, 2010 I was blind now I can see. Ain't life grand? Welcome to the CADTutor forum fohlmann. Quote
