Cbraunheim Posted March 24, 2010 Posted March 24, 2010 I am designing a kiosk in AutoCAD2008 3D. I would like to show the plexiglass window panels as transparent. As soon as I change the material using the Global Map, the entire project turns transparent, even though I only selected the panels. I made them with the solid box command. Is there something I am missing? Thanks in advance! Fisher Kiosk 3-24-10.dwg Quote
Cbraunheim Posted March 26, 2010 Author Posted March 26, 2010 Good Morning! Happy Friday! Thank you for responding - I simply drew solids from the Dashboard. Quote
Cad64 Posted March 26, 2010 Posted March 26, 2010 Don't use the first material slot. That is a Global Material and will be applied to all objects in your scene. You should leave that material slot alone and create a new material, make that your glass material and apply that to your windows. Quote
Cbraunheim Posted March 26, 2010 Author Posted March 26, 2010 Fabulous! That worked - thank you very much! Quote
