AC2Designs Posted March 24, 2010 Posted March 24, 2010 Just wondering if the .Angle property of a line returns the angle in radians or degrees. Any advice on a great reference guide for AutoCAD vbdotNET. The AutoDesk vbdotnet developer's guide is good, but very limited. Thanks, Kevin Quote
fixo Posted March 24, 2010 Posted March 24, 2010 Just wondering if the .Angle property of a line returns the angle in radians or degrees. Any advice on a great reference guide for AutoCAD vbdotNET. The AutoDesk vbdotnet developer's guide is good, but very limited. Thanks, Kevin Take a look at this site http://docs.autodesk.com/ACD/2010/ENU/AutoCAD%20.NET%20Developer%27s%20Guide/index.html?url=WS73099cc142f48755-5c83e7b1120018de8c0-1fdb.htm,topicNumber=d0e42241 ~'J'~ Quote
AC2Designs Posted March 25, 2010 Author Posted March 25, 2010 I have that link, and it is good, but as I said very limited. And unfortunately does not have anything about the properties of a Line object. Quote
SEANT Posted March 25, 2010 Posted March 25, 2010 Angles are always expressed as radians within the API. They would only be converted to Degrees (or Grads, Surveyor units) during user interface. See the useful AutoDesk.AutoCAD.Runtime.Converter class for that phase. Quote
fixo Posted March 25, 2010 Posted March 25, 2010 I have that link, and it is good, but as I said very limited.And unfortunately does not have anything about the properties of a Line object. Here is a quick code, see result in the command line Public Shared Sub SelectLines() Dim doc As Document = acadApp.DocumentManager.MdiActiveDocument Dim db As Database = HostApplicationServices.WorkingDatabase Dim ed As Editor = doc.Editor Dim tr As Transaction = db.TransactionManager.StartTransaction() Try Using tr Dim tvs As TypedValue() = New TypedValue() {New TypedValue(DirectCast(DxfCode.Start, Integer), "LINE")} Dim sf As New SelectionFilter(tvs) Dim psr As PromptSelectionResult = ed.SelectAll(sf) Dim sset As SelectionSet = psr.Value If sset.Count = 0 Then Return End If For Each sobj As SelectedObject In sset Dim dbobj As DBObject = tr.GetObject(sobj.ObjectId, OpenMode.ForRead) Dim line_obj As Line = TryCast(dbobj, Line) If line_obj <> Nothing Then Dim ang As Double = line_obj.Angle ''<--always in radians ed.WriteMessage(vbLf & "Angle = {0} radians, {1} degrees", Math.Round(ang, 3), Autodesk.AutoCAD.Runtime.Converter.AngleToString(ang, AngularUnitFormat.Degrees, 3)) < process lines here > End If Next tr.Commit() End Using Catch ex As System.Exception ed.WriteMessage(ex.Message + vbLf + ex.StackTrace) End Try End Sub You can also use Intellsense to show properties and methods in the editor ~'J'~ Quote
AC2Designs Posted March 25, 2010 Author Posted March 25, 2010 I will try this thank you. Do you know of a good resource for all the autodesk.autocad.stuff.morestuff etc.? I've learned a bit just by searching, the autodesk developers guide, and trial and error; but I'd like something more comprehensive. Thanks for your help, Kevin Quote
fixo Posted March 25, 2010 Posted March 25, 2010 I will try this thank you. Do you know of a good resource for all the autodesk.autocad.stuff.morestuff etc.? I've learned a bit just by searching, the autodesk developers guide, and trial and error; but I'd like something more comprehensive. Thanks for your help, Kevin Unfortunately, no Still going the same way Happy coding ~'J'~ Quote
