3dsmaxed Posted August 21, 2008 Posted August 21, 2008 Hi all i installed autocad 2009 on my 64 bit windows i have installed dot net fx 3.0 and also visual C++ 2005 and latest version of direct x. after that i installed acad 2009 it installed fine but when i launch the application i am getting this error. "FATAL ERROR- The security sysetm(softlock license manager) is not functioning or is not properly installled." can anyone help me fix this? Thanks Quote
Strix Posted August 21, 2008 Posted August 21, 2008 do any of these suggestions answer your question? Quote
3dsmaxed Posted August 22, 2008 Author Posted August 22, 2008 no they dont i installed dot net fx 3.0 , direct x latest and visula c++ 2005 latest i had installed it before around a month back but its not installing now Thanks Quote
dewain0606 Posted June 27, 2009 Posted June 27, 2009 the best thing to do is delete it, uninstall then do a system restore then reinstall it Quote
nailer341 Posted November 19, 2009 Posted November 19, 2009 so what was the fix for this issue? I have the same problem and am having no luck finding a solution. Quote
ReMark Posted November 19, 2009 Posted November 19, 2009 I found an article on the AutoDesk website that references the error message having to do with the Softlock License Manager not functioning or being improperly installed. However it was in regards to AutoCAD 2000 and not a later release. Maybe the info contained within is of some value. http://usa.autodesk.com/adsk/servlet/ps/item?siteID=123112&id=2877622&linkID=9240617 Quote
