Re-Ordering Lookup Table Attributes (screen picture attached)
When I placed my lookup tables into my drawing, I need them to appear in a different order in the properties menu on the left of the sceen. (This is within the "Custom" property section)
Can this be done?
*Attached is a screen picture*
PICTURE URL: http://i44.tinypic.com/vecf0k.jpg
I am not familiar with LISP but would I just drag the file that they had me download into the AutoCAD folder in "C:\Program Files\AutoCAD" ?
Download file
@ AutoCAD command line: appload
Browse to .lsp file, select Load
@ AutoCAD command line: (move-properties)
Well honestly, there is no reason to have those 3 in there. If it is just as easy to delete them out as it is to make them not print, then I would chose just delete them out of there.
Command line:
Insert
Architectural Title Block
{insert it somewhere off of the paper}
attsync
Select the inserted "Architectural Title Block"
Delete the inserted "Architectural Title Block"
At some point those attributes were deleted from the "Architectural Title Block", but the block was never synced. So they there in an old definition, and when you sync the block to the defined that doesn't have them, they go away.
If they were still there, then you could have inserted the "Architectural Title Block", refedit it, change the attribute properties of INVISIBLE from No to Yes, and they would have been retained, but not seen.
That worked! I think you may be a genius, or I just might be uneducated...
