I have a room number block that can have room numbers vary from 4 to 8 characters. I have been using view parameters but would like the enclosing rectangle to stretch around the attribute automatically when the attribute is typed in. Is this possilbe? I have tried distance parameter and that does not operate properly.
  • 2 weeks later...
can I get a snapshot of yours???...
MarkV,
Your can try with the command "tcircle". But it does not work with Attributes...
You are using a Dynamic block right?
I am using a dynamic block. I have attached the file. IF you look at the different views i am using you will see what I am trying to accomplish
room number.dwg
without using programming I think the best you can do is visibility states (like you have) or a stretch box, as attatched (I hope).
room number-str.dwg
