I am trying to remove a specific dictionary from a bunch of files. The client we work with has issues in their document management system when this exists in the files. I am trying to get this to work so that it prints whether it did not already exist, or if it was deleted. Right now I keep getting an error that says:
error: bad function:
Here is what I have so far:
(defun c:GCI()
(setq newdictlist (dictsearch (namedobjdict) "GcImageDef_Dict"))
(If
(= nil newdictlist) (princ "\nGcImageDef_Dict does not exist.")
((dictremove (namedobjdict) "GcImageDef_Dict") (princ"\nThe GcImageDef_Dict has been removed."))
Thanks in advance for any help!
I can't test it, but maybe something like this?
(defun c:GCI  (/ newdictlist)
 (cond (  (setq newdictlist (dictsearch (namedobjdict) "GcImageDef_Dict"))
          (princ "\nThe GcImageDef_Dict has been removed."))
       (  (princ "\nGcImageDef_Dict does not exist.")))
 (princ))
Lee, Thanks! Thats works. By chance, can you explain why it would return that error for me. In theory, to my knowledge that should work. I mean, my version DID work, it jsut put that error after printing "...has been removed." Thanks again!
-Dan
It was this line:
Which would be interpreted as:
(<entity_name>   "\nThe GcImageDef_Dict has been removed.")
I.e. as if the was a function, (which it isn't, of course).
To wrap two expressions in the THEN statement of the IF function, you need to use a wrapper like PROGN:
  (If (= nil newdictlist)
   ) ; progn
 ) ; IF
(princ))
i think the issue is your IF statement (= nil newdictlist) should be
(= newdictlist nil)
