Phil-Bert Posted March 29, 2010 Posted March 29, 2010 Using AutoCAD 2010. Can anyone give me some information about opening a file that may contain incorrect or corrupted information? I try to open a file, it shows a preview in the open dialog window, but when i push the open button, I get the following message: Unable to open this drawing. It contains incorrect or corrupted information. The RECOVER command may be able to restore undamaged material from this drawing. When I try the recover command on the drawing, Autocad shuts down part way thru. Any help would be greatly appreciated. Thanks, Bert Quote
Phil-Bert Posted March 29, 2010 Author Posted March 29, 2010 Thanks for the suggestion, but it didn't work. Told me it may need to be recovered. Quote
fuccaro Posted March 30, 2010 Posted March 30, 2010 The Partial Open helped me once or twice. Also it worth to try importing the drawing in an other software that can open DWGs, like SolidWorks. Quote
Phil-Bert Posted March 30, 2010 Author Posted March 30, 2010 What version was the drawing saved in? It was saved in 2010. I am using 2010. Quote
Phil-Bert Posted March 30, 2010 Author Posted March 30, 2010 The Partial Open helped me once or twice. Also it worth to try importing the drawing in an other software that can open DWGs, like SolidWorks. I tried the partial open option. Couldn't get it to work. I don't have access to Solid works. Thanks for the suggestioins. Quote
Phil-Bert Posted March 30, 2010 Author Posted March 30, 2010 Have you tried using DWG TrueView? I tried TrueView also and Microstation. The only other option I can come up with is that there is some kind of security setting on it. We are going to contact the originator of the drawing and hopefully they can help. Thanks to everyone for all the suggestions. Quote
ReMark Posted March 30, 2010 Posted March 30, 2010 If it had security on it you would get a vastly different message. Can you post the file and let someone here have a go at it? Quote
Phil-Bert Posted March 30, 2010 Author Posted March 30, 2010 If it had security on it you would get a vastly different message. Can you post the file and let someone here have a go at it? I can't post the file. We are strickly prohibited from that. Thanks for your help. Quote
Hoozin Posted March 30, 2010 Posted March 30, 2010 One last try: Open a blank drawing and INSERT the bad drawing as a block. Quote
Jadeous Posted May 4, 2011 Posted May 4, 2011 Using ACAD 2010 Resently changed from 2005 OS - Windows 7 Home Pre, 64bit I have had this very same problem that arose only days ago. I can open these files in 2005 just fine, yet if i try to open in 2010 I get that message. But only on "select" dwg's, not all. Quote
Jadeous Posted May 4, 2011 Posted May 4, 2011 This is an example of one of the drawings that I get that message with. Any help would be great! Thanks in advance. P3.0.dwg Quote
SLW210 Posted May 4, 2011 Posted May 4, 2011 I got the message to recover and it recovered fine for me....you should open in AutoCAD 2005 and run an audit. Validating objects in the handle table. Valid objects 894 Invalid objects 0 Validating objects completed. Salvaged database from drawing. Auditing Header Auditing Tables Auditing Entities Pass 1 Pass 1 700 objects audited Auditing Entities Pass 2 Pass 2 200 objects auditedAcDbDimStyleTableRecord: "1to48" Not in Table Added Pass 2 700 objects audited Auditing Blocks 23 Blocks audited Total errors found 1 fixed 1 Erased 0 objects Opening an AutoCAD 2004/LT 2004 format file. Xref "Zbase01": Zbase01.dwg "Zbase01" is unloaded. Resolve Xref "Xbrdr": Xbrdr.dwg "Xbrdr.dwg" cannot be found. Resolve Xref "Zbase01-Rev": C:\Documents and Settings\Owner\My Documents\My Dropbox\6815 Flanders\Suite 100\Design\Zbase01-Rev.dwg "Zbase01-Rev.dwg" cannot be found. Regenerating layout. Regenerating model. AutoCAD menu utilities loaded.*Cancel* Autodesk DWG. This file is a TrustedDWG last saved by an Autodesk application or Autodesk licensed application. Quote
