Autodesk Land Enabled Map 2004 - I'm having trouble exporting a shapfile.
I'm using Autodesk Land Enabled Map 2004 and when I export to a shapefile I get this error...
0 object(s) of 136 selected, exported in 0 sec(s).
It selects the objects (136 in my case) but it just doesn't export them.
Does anyone have a solution?
Okay... I figured it out.
It was rather simple, I did not have a proper coordinate system assigned. Once I fixed this, everything went as expected.
