How to draw using east and northing coords
Hi all,
I'm using autocad 2010 full and being very new to autocad as i have recently passed my 2d level 2 course and now going on to level 3.
My question is can and how do i for instance draw a building using east and north coordinates? i.e i have sat on a point which is 500 east and 500 north and surveyed points on the corners of a building for example;
point 1, 492.405e 511.030n
point 2, 493.273e 508.447n
point 3, 490.618e 507.489n
and so on.
I know that surveying uses whole circle bearing which 0 degrees is at 12 o'clock and moves clockwise and in autocad 0 degrees is at 3 o'clock and moves anti clockwise.
Or do i need to purchase 3d civil?
all help will be much appreciated
Easting= X coordinate
Northing= Y coordinate
so...
point 1 = 492.405,511.030
Silly me sorry yes and just input the next point as an absolute co-ord isn't it, can tell i've only just started using it lol.
Okay would i be right in saying i would set the drawing limits as say a couple of metres higher and lower than the smallest and largest easting and northings?
To be truthful I haven't screwed around with Limits since the days of DOS Acad; there's no real point in setting the limits unless you like to have the grid displayed.
sorry thats two stupid questions, oh what the hell lets go for 3, so how could i import the co-ords on a excel sheet straight into autocad?
thanks for the all the advice by the way
Thankyou Ipseifert you've been really helpful, since clapping my eyes on this program and finding out some of the things you can do with it i just want to learn more, it's a lot to take in but i'm loving it.
If you want to draw a 3D polyline to connect the dots try this:
In excel get your data in x,y,z format. This can be done by creating an equation to concatenate the data; e.g =A1&","&B1","&C1 where cells A1, B1 and C1 hold the x, y and z values. Highlight the new column and press Ctrl+C (copy). In autocad start the 3dpoly command, when it prompts you for a start point, paste the coordinates (Ctrl+V) at the command line.
Sorry to be a pain but can anyone show me how i do this in excel
Firstly, thanks for the link Larry, appreciated.
Rob, if you choose to use my program, it can import from txt/csv, so you could easily save a copy your Excel file into CSV format, and then import the points using my program. :)
  • 1 month later...
hi, im new to Autocad. i got Lot Data but dont know how to draw this in autocad. im using autocad 2007.
Lot Data:
Monumentation
Northing Easting Elevation
2810960.880 352682.156 156.871
2810989.468 352666.806 156.276
2810969.643 352700.493 156.900
2810975.262 352663.593 157.075
2811000.809 352689.082 157.276
Check out the links that the users have provided above :)
