clemson77on Posted March 31, 2010 Posted March 31, 2010 Is there a setting that will erase the lines used to make a polyline with th boundary command? Example: I have 4 lines that create a square. I use the boundary command to create polyline. Now I have a square polyline on top of the 4 lines. I then have to manually erase the 4 lines. Quote
BearDyugin Posted March 31, 2010 Posted March 31, 2010 If the end of a line coincides with the beginning of another, you can use a command PL-CSE pltools.lsp Quote
maratovich Posted April 5, 2020 Posted April 5, 2020 ^C^C(defun C:JPL ( / ope ssnab )(setq ope (getvar "PEDITACCEPT"))(setvar "PEDITACCEPT" 1)(setq ssnab (ssget "_I"))(while (not ssnab)(setq ssnab (ssget)))(command "_pedit" "_Multiple" ssnab "" "_Join" 0 "")(setvar "PEDITACCEPT" ope)(setq ssnab nil)(princ));JPL; Quote
jagwinn Posted June 9, 2020 Posted June 9, 2020 Create layer for BOUNDRY; Create layer for PLINE; Draw boundry on BOUNDRY layer, and change to layer PLINE and draw pline. Change to BOUNDRY layer and FREEZE PLINE layer. Erase Boundry geometry. UnFreeze PLINE layer. Job done. Quote
BIGAL Posted June 9, 2020 Posted June 9, 2020 Like jagwin, make boundary get all the vertices co-ords, turn off boundary, use ssget "f" co-ords then erase, turn boundary back on. A word of caution the erase is brutal. Quote
