how to convert 2d Polyline to 3d Polyline
Hi All,
I gave 2d poly line with curves as an input now i want to convert that 2d poly line into 3d poly line with bulge factor and with points. after that i want to draw a 3dpolyline with that same points in future how we achieve this in vba
thanks in advance
Does 2006 have the ConvertPlines command?
3d polylines can have only straight segments, no curves.
you can approximate the curve with short segments in a 3d polyline.
**EDIT**
OK I see this is being hashed out in the lisp/customization forum where you also posted.....
