DAVE OWENS Posted April 5, 2010 Posted April 5, 2010 I have a new problem that happened this morning. Last friday when I left the office, my AutoCad looked normal. I have a wide screen monitor, my drawings are strecthed left to right a small amount. This morning, my drawings are stretched quite a bit more. Even my border template is stetched out of shape. It looks like it is at least 20% wider than normal, which is really throwing off my perception. Would this be a problem in my AutoCad or computer settings, I can't seem to figure it out. I am currently running with Windows Vista & AutoCad 07. Any help would be greatly appreciated Thank You Quote
f700es Posted April 5, 2010 Posted April 5, 2010 If they are even stretched a bit it sounds like a video driver or setting error. Check your display settings in Vista. You probably need to adjust it to a wide screen's resolution. Quote
ScribbleJ Posted April 5, 2010 Posted April 5, 2010 One way to determine if your aspect ratio is out of whack is to draw a circle. If it appears as an ellipse then you need to adjust your screen resolution as f700es stated. Quote
