Is there a function for drawing a closed traverse? I have the adjusted bearing and distance from our six point closed traverse survey but I have no idea how to find a starting point on the drawing. I believe my query is vague but this is all the info I have. The TA is out for the week and nobody in the class has a clue that I know. I'm using Autocad 07, 09, and 10. I save all work as 2007.dwg
Thanks,
Mark
Unless you are using Land Developement Desktop or Civil 3D then you have to use the normal commands for drawing a close traverse.
Example: @215
You say you have the bearings/distances. Unless you have coordinates for the Point of Beginning, just start at 0,0 and enter them as such...
Command: LINE
Specify first point: 0,0
Specify next point or [undo]: @123.45
Specify next point or [undo]: @135.45
Thank you very much, I did as you suggested and it worked out fine.
