woodman78 Posted April 7, 2010 Posted April 7, 2010 How can I set the layer colour to truecolour? When I try using cons 62 I keep getting errors. I tried creating a new varialbe which is set to the truecolour and then set cons 62 equal to that but no joy. Quote
TimSpangler Posted April 7, 2010 Posted April 7, 2010 How can I set the layer colour to truecolour? When I try using cons 62 I keep getting errors. I tried creating a new varialbe which is set to the truecolour and then set cons 62 equal to that but no joy. Here is some info that may be helpful ;;; Copyright (C) 2003 by Autodesk, Inc. ;;; ;;; Permission to use, copy, modify, and distribute this software ;;; for any purpose and without fee is hereby granted, provided ;;; that the above copyright notice appears in all copies and ;;; that both that copyright notice and the limited warranty and ;;; restricted rights notice below appear in all supporting ;;; documentation. ;;; ;;; AUTODESK PROVIDES THIS PROGRAM "AS IS" AND WITH ALL FAULTS. ;;; AUTODESK SPECIFICALLY DISCLAIMS ANY IMPLIED WARRANTY OF ;;; MERCHANTABILITY OR FITNESS FOR A PARTICULAR USE. AUTODESK, INC. ;;; DOES NOT WARRANT THAT THE OPERATION OF THE PROGRAM WILL BE ;;; UNINTERRUPTED OR ERROR FREE. ;;; ;;; Use, duplication, or disclosure by the U.S. Government is subject to ;;; restrictions set forth in FAR 52.227-19 (Commercial Computer ;;; Software - Restricted Rights) and DFAR 252.227-7013(c)(1)(ii) ;;; (Rights in Technical Data and Computer Software), as applicable. ;;; ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;; ;; This file contains lisp utilities for dealing with true color in AutoCAD. ;; ;; AutoCAD describes true color with 24 bit integer values where ;; - blue is the first byte ;; - green is the second and ;; - red is the third byte ;; ;; (Careful... This is not exactly a RGB value. It is a BGR.) ;; ;; Within the scope of this file, the term "TrueColor" refers to one of these 24 bit ;; values. The term "ColorIndex" will be used to refer to the traditional AutoCAD ;; colors that range from 0 through 256 (where 0 and 256 have the special meanings of ;; "ByBlock" and "ByLayer" respectively) ;; ;;------------------------------------- ;; Entity lists and dxf group codes: ;;------------------------------------- ;; DXF ;; 62 - ColorIndex values are still represented with the 62 dxf group code (same as in ;; previous AutoCAD releases). ;; ;; 420 - TrueColor values are associated with the new 420 dxf group code. ;; For example: You might find (420 . 255) within the entity list of a blue entity. ;; ;; 430 - Contains a color book and color name description string. This is used only for ;; informational purposes. Actual entity color is governed by 62 and/or 420 group ;; codes. ;; ;;Entity lists... ;; ;; Entget: ;; No 62 pair present - If no 62 group code is present then the object's color is assumed to be ;; ByLayer. In other words; No behavior change from previous releases. ;; (The 420 and 430 pairs will not be present either) ;; ;; 62 only - Object's color is by ColorIndex (also refered to as ByACI) ;; ;; 62 and 420 - Object's color is TrueColor and is fully described by the 420 group code. ;; The 62 pair will contain the colorindex that most closely matches the true ;; color. ;; ;; 62, 420 and 430 - Object color was chosen from a color book. The 430 contains a textual description ;; of the form "'colorbook$colorname". The 420 pair describes the ;; corresponding truecolor and the 62 contains the closest matching color ;; index. ;; ;; ;; Entmod and Entmake: ;; The 420 group code takes precedence over the 62 group code. That is; entmake or entmod will ;; use the 420 group code if it is present and will ignore the 62 group code in the provided ;; entity list. If a 420 is _not_ present in the entity list, then the 62 group code will ;; be used. The 430 group code is for informational purposes only and does not have ;; any effect on displayed color. ;; ;;------------------------------------- ;; Two new built in lisp functions: Acad_TrueColorDlg and Acad_TrueColorCli ;;------------------------------------- ;; ;; Acad_TrueColorDlg is somewhat similar to the existing acad_colordlg function. ;; Signature: ;; (acad_truecolordlg color [allowbylayer] [currentlayercolor]) ;; ;; Where "color" is a dotted pair that describes the default color. The first element ;; of the dotted pair must be one of the color dxf group codes (62, 420, or 430). ;; For example: ;; (62 . ColorIndex) ;; (420 . TrueColor) ;; (430 . "colorbook$colorname") ;; ;; If the optional [allowbylayer] parameter is present and non-nil, then the bylayer and ;; byblock buttons will be enabled. If this parameter is missing, the value defaults to ;; T and the bylayer/bylbock buttons will be enabled. ;; ;; The optional [curLayerColor] parameter controls the color of the bylayer/byblock color ;; in the dialog. This parameter is also a dotted pair like the first color parameter. ;; ;; Returns nil if the user canceled. ;; On success, the function returns a list of one or more dotted pairs that fully describe the ;; chosen color. The last dotted pair in this list indicates, specifically, the color that was ;; chosen. Additional details on the return list follow... ;; ;; ColorBook color - If the last item in the returned list is a 430 pair, then the specified ;; color originates from a colorbook. (This returned list will also contain ;; a 420 pair that describes the corresponding truecolor and a 62 pair that ;; describes the closest matching colorindex value.) ;; ;; True Color - If the returned list contains a 420 pair as the last item, then ;; a true color was specified (as "Red,Green,Blue"). The list will ;; also contain a 62 pair that indicates the closest matching colorindex. ;; (No 430 pair will be present) ;; ;; Color Index - If the last item in the list is a 62 pair, then a colorindex was chosen. ;; (no other dotted pairs will be present in the returned list) ;; ;; Examples of usage: ;; (acad_truecolordlg '(62 . 1)) ;; (acad_truecolordlg '(420 . 2686760)) ;; (acad_truecolordlg '(430 . "Color Book Sample File$Sample 0C")) ;; (acad_truecolordlg '(420 . 2686760) nil) ;; ;; ;; ;; Acad_TrueColorCli is the command line counterpart to acad_truecolordlg. It prompts at the command line ;; for a color. ;; Signature: ;; (acad_truecolorcli color [allowbylayer] [alternatePrompt]) ;; ;; The first two parameters are identical to acad_truecolordlg, and the third parameter ;; is an optional prompt string. If this string is omited, the default value is "New color ". ;; ;; Some examples of lists returned by acad_truecolordlg and acad_truecolorcli: ;; Color book color: ((62 . 80) (420 . 2686760) (430 . "Color Book Sample File$Sample 0B")) ;; True color: ((62 . 162) (420 . 2114527)) ;; color index: ((62 . 110)) ;; ;; ;; ;; ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;; Get the red component of a TrueColor number ;; (defun TrueColor-red-value ( c / ) (lsh (fix c) -16) );defun TrueColor-red-value ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;; Get the green component of a TrueColor number ;; (defun TrueColor-green-value ( c / r ) (lsh (lsh (fix c) 16) -24) );defun TrueColor-green-value ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;; Get the blue component of a TrueColor number ;; (defun TrueColor-blue-value ( c / ) (lsh (lsh (fix c) 24) -24) );defun TrueColor-blue-value ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;; TrueColor-split - takes a TrueColor number and returns a list of integers the form '(red green blue) ;; (defun TrueColor-split ( c / ) (list (lsh (fix c) -16) (lsh (lsh (fix c) 16) -24) (lsh (lsh (fix c) 24) -24) ) );defun TrueColor-split ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;; TrueColor-make - takes TrueColor components (red green blue) and creates a single TrueColor integer ;; (defun TrueColor-make ( r g b / ) (+ (lsh (fix r) 16) (lsh (fix g) (fix b) ) );defun TrueColor-make ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;; TrueColor-to-ColorIndex - takes a TrueColor value and returns the closest AutoCAD color index (1-255) ;; NOTE: This is an approximation. The return color index is the AutoCAD color index that most ;; closely matches the provided TrueColor. ;; (defun TrueColor-to-ColorIndex ( TrueColor / colorObj ci ) (vl-load-com) (and (setq colorObj (vla-getinterfaceobject (vlax-get-acad-object) "AutoCAD.AcCmColor.16")) (not (vl-catch-all-error-p (vl-catch-all-apply 'vla-setRGB (cons colorObj (TrueColor-split TrueColor))) ) ) (setq ci (vla-get-ColorIndex colorObj)) );and ci );defun TrueColor-to-ColorIndex ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;; ColorIndex-to-TrueColor - takes an AutoCAD color index (1 through 255) and returns the equivalent ;; TrueColor value. ;; (defun ColorIndex-to-TrueColor ( ci / colorObj TrueColor ) (vl-load-com) (and (setq colorObj (vla-getinterfaceobject (vlax-get-acad-object) "AutoCAD.AcCmColor.16")) (>= ci 1) (<= ci 255) (not (vl-catch-all-error-p (vl-catch-all-apply 'vla-put-ColorIndex (list colorObj ci)) ) ) (setq TrueColor (TrueColor-make (vla-get-red colorObj) (vla-get-green colorObj) (vla-get-blue colorObj) ) );setq );and TrueColor );defun ColorIndex-to-TrueColor ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;; colorname-to-truecolor - converts a string of the form "colorbook$colorname" to a TrueColor value. ;; (defun colorname-to-truecolor ( colorbookandname / pos colorbook colorname colorObj TrueColor ) (vl-load-com) (and (equal (type colorbookandname) 'STR) (setq pos (vl-string-search "$" colorbookandname)) (setq colorbook (substr colorbookandname 1 pos) colorname (substr colorbookandname (+ pos 2)) );setq (setq colorObj (vla-getinterfaceobject (vlax-get-acad-object) "AutoCAD.AcCmColor.16")) (not (vl-catch-all-error-p (vl-catch-all-apply 'vla-SetColorBookColor (list colorObj colorbook colorname)) ) ) (setq TrueColor (TrueColor-make (vla-get-red colorObj) (vla-get-green colorObj) (vla-get-blue colorObj) ) );setq );and TrueColor );defun colorname-to-truecolor ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;; TrueColor-to-RGBstring - Takes a TrueColor (24 bit value) and returns a string of the ;; form: "Red,Green,Blue" ;; (defun TrueColor-to-RGBstring ( TrueColor / rgb ) (and truecolor (setq rgb (mapcar 'itoa (truecolor-split truecolor))) (setq rgb (strcat (car rgb) "," (cadr rgb) "," (caddr rgb))) ) rgb );defun TrueColor-to-RGBstring ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;; ssget-ColorIndex-filter - ;; Takes an AutoCAD color index (0 through 256) and ;; returns a dxf group code list that can be used with (ssget ...) to ;; select all objects that "exactly" match the specified AutoCAD ColorIndex. ;; This allows you to filter for objects that are of a specific AutoCAD ;; ColorIndex (0-256) but are not assigned a true-color value. ;; ;; For example: ;; The following will return a selection set that contains "red" objects ;; _and_ objects that are assigned a true color that is merely "close" to red. ;; ;; (setq ss (ssget "_x" '((62 . 1)))) ;; ;; If you do not want true-color objects and only want to select objects that are ;; explicitly set to color number 1 ("red") then you can use the following code. ;; This will return a selection set of all non-true-color entities that are color 1. ;; ;; (setq ss (ssget "_x" (ssget-ColorIndex-filter 1))) ;; ;; ;; (defun ssget-ColorIndex-filter ( ColorIndex / ) (list (cons 62 ColorIndex) '(-4 . "<NOT") '(-4 . "*") '(420 . 0) '(-4 . "NOT>")) ) ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;; entlist-set-ColorIndex ;; Takes an entity list and an AutoCAD ColorIndex (0 through 256) ;; Returns the entity list with the specified color setting applied. ;; This returned list can then be used with (entmake ...) or (entmod ...). ;; NOTE: This function does _not_ call entnake or entmod. It only manipulates ;; the provided list and returns the resulting list. ;; ;; Backround: ;; If a 420 group code pair (true color) is present in an entity list, entmake and entmod ;; will ignore the 62 group code (AutoCAD ColorIndex). In order to set a color index ;; using entmod or entmake, the provided list must not contain a 420 group code. ;; This function allows you to apply a specific AutoCAD ColorIndex value to an entity list ;; by removing the 420 group code (if present) and inserting the specified ColorIndex with ;; a 62 group code pair. ;; ;; (provide a ColorIndex of 0 for ByBlock and 256 for ByLayer) ;; (defun entlist-set-ColorIndex ( entlist ColorIndex / ci ) (setq entlist (vl-remove (assoc 420 entlist) entlist)) (if (setq ci (assoc 62 entlist)) (setq entlist (subst (cons 62 ColorIndex) ci entlist)) (setq entlist (append entlist (list (cons 62 ColorIndex)))) );if );defun entlist-set-ColorIndex (princ) Quote
woodman78 Posted April 8, 2010 Author Posted April 8, 2010 I have tried to get the truecolour to work but I come up against this: The colour is set like this in the code: (cons 0 "LAYER") (cons 100 "AcDbSymbolTableRecord") (cons 100 "AcDbLayerTableRecord") (cons 2 b) (cons 6 a) (cons 62 1) (cons 420 127100100) (cons 70 0) (cons 370 lw)))) But the layer colour ends up being 147,100,196. Anyone any ideas? Quote
Lee Mac Posted April 8, 2010 Posted April 8, 2010 That cannot be right Woodman as 127100100 is greater than the TrueColour maximum of 16777215 (= 255x65536 + 255x256 + 255) Use (defun TrueColor-make ( r g b / ) (+ (lsh (fix r) 16) (lsh (fix g) (fix b) ) ) To get the correct colour code. Quote
mikarts Posted October 10, 2010 Posted October 10, 2010 First you may get the truecolor number like Lee Mac says. Then, this works for me: (defun LayerTC () (entmake (list (cons 0 "LAYER") (cons 100 "AcDbSymbolTableRecord") (cons 100 "AcDbLayerTableRecord") (cons 2 "NameLayer") (cons 62 198) (cons 420 3080253) (cons 70 0))) ) Quote
harinezumi Posted January 15, 2014 Posted January 15, 2014 I come to this thread trying to add RGB colors to the great TimSpangler's Layer Creator routine. But my programming skill is useless. Tim, would you ever update your lisp to suppport RGB colors? Thenk you Quote
