Is there someone that can help me with some code that will get a selection set containing "Point Move Parameter Sets" created in the Block Editor in order to move a very large group of items without actually moving the entire block with these points? I've attached a dwg with some dynamic blocks that use these points. Any help is much appreciated.
Thanks in advance,
jb
junk.dwg
There is no need to double post. It just confuses things. Thank you and be patient.
Sorry, I realize that the dwg attachment was posted with the previous thread but this is a completely different issue. Should I remove the attachment and refer to the other thread?
jb
If you have two distinctly different issues then fine leave things as they are. If the issues are inter-related then perhaps it is better if you combine them. Thank you.
