Dana W Posted April 16, 2010 Posted April 16, 2010 i meant the amount of wood needed to process that much paper to plot on, silly Well, they are scale trees. Quote
MikeScott Posted April 16, 2010 Posted April 16, 2010 My Professors logic behind using limits is so you have a border around the drawing for notes or something. I SHOULD be doing this.. I have a tendency (with 2d drawings) to do the drawing, and import other drawings for reference and/or for swiping details, or previous designs that we might go back to, etc. It turns into a real mess sometimes. To show which drawing is "current" I always put a large square around the "active" drawing, and draw x's over the reference stuff... so there's no mistake. (I use a layer called "noplot" that's always red, and set to not plot.. it's my personal guidelines etc, and my "current box"..) I suppose I COULD keep the active stuff in the limits area, and everything else outside of it. That would likely make more sense to someone wandering into my drawings and trying to make sense of them. When a design is finalized, I clear all that out, but until then, there's often a lot of stuff there. Quote
Dana W Posted April 16, 2010 Posted April 16, 2010 I SHOULD be doing this.. I have a tendency (with 2d drawings) to do the drawing, and import other drawings for reference and/or for swiping details, or previous designs that we might go back to, etc. It turns into a real mess sometimes. To show which drawing is "current" I always put a large square around the "active" drawing, and draw x's over the reference stuff... so there's no mistake. (I use a layer called "noplot" that's always red, and set to not plot.. it's my personal guidelines etc, and my "current box"..) I suppose I COULD keep the active stuff in the limits area, and everything else outside of it. That would likely make more sense to someone wandering into my drawings and trying to make sense of them. When a design is finalized, I clear all that out, but until then, there's often a lot of stuff there. You 'splain it mo' betta than me, but that is kinda what I do too, and I even draw a box around the good stuff, sometimes. I worked for a guy once who insisted we keep pre-revision drawings IN the same drawing, framed and labeled. I guess he never quite caught on to the concept of Save as Smith Kitchen REV 3. Quote
