cadamrao Posted April 12, 2010 Posted April 12, 2010 Hi friends When I going to check my contractor drawings, I had faced one problem in AutoCAD drawing; they had created double line, polylines and text. Please guide me how to remove (line, polyline and text) one duplicate object. If any LISP; plz help Thanks amrao Quote
lpseifert Posted April 12, 2010 Posted April 12, 2010 Try the Express Tools' Overkill command. Set Peditaccept=0 prior to running. or if that doesn't work (sometimes squirrely) look here for Clear.lsp http://cadtips.cadalyst.com/node/tiplisting?keywords=clear Quote
alanjt Posted April 12, 2010 Posted April 12, 2010 Set Peditaccept=0 prior to running. Why do you say that? I've had peditaccept set to 1 for years and never encountered a problem with OverKill. Quote
lpseifert Posted April 12, 2010 Posted April 12, 2010 I was having problems with Overkill not always working properly, then I read this thread http://discussion.autodesk.com/forums/thread.jspa?threadID=581147 and it helped heaps. Quote
alanjt Posted April 12, 2010 Posted April 12, 2010 I was having problems with Overkill not always working properly, then I read this thread http://discussion.autodesk.com/forums/thread.jspa?threadID=581147 and it helped heaps. Service Unavailable The server is temporarily unable to service your request. Explanation The server is unable to service a request because a needed resource is unavailable. Solution Please try again later. I guess I'll read it later. I will give it a look. I use OverKill occasionally. Thanks. Quote
