andrew239 Posted April 12, 2010 Posted April 12, 2010 Hello there, I am new to the batch plot environment, and am having some problems in batch plotting pdfs as single sheets. In a single drawing i can select all of the layouts, and publish them as single sheet pdf's using the single sheet output option in the publish options dialogue box. The problem comes when I try to do this using a sheet set of layouts from various drawings. Even when the single sheet option is used, it still prints all of the layouts in a sinle pdf with multiple pages. As far as I can tell, the publishcollate command is not available in autocad 2007. Any help would be greatly appreciated. thanks in advance. Quote
Dana W Posted April 12, 2010 Posted April 12, 2010 I"m pretty sure the Sheet Set option assumes you want it all in one document. I used to use that at work a lot with Acad 2007. The only place I can find a single page per doc option is in DWF publishing. But then my LT 2009 does not have sheet sets, and I don't "Work" any more. Quote
andrew239 Posted April 13, 2010 Author Posted April 13, 2010 Thanks for your response Dana, i thought that was the case, just wanted to be sure i wasnt missing something. Quote
alanjt Posted April 13, 2010 Posted April 13, 2010 We started using a program called BlueBeam to avoid issues with plotting documents with several HUGE images and it works like a dream. The user has 11 different file format options to choose from. Quote
