M76 Posted April 13, 2010 Posted April 13, 2010 I'm trying to create a listbox with dcl, to be able to select multiple items. But I can't find any hint how to go about it, the only example I could find in autocad is this: (defun selectItem( lstItems dcl-fileName dialogName / dcl_id LT lstLinkTemplates selectedItem) (setq dcl_id (load_dialog dcl-filename)) ; Load the DCL file (if (not (new_dialog dialogName dcl_id)) ; Initialize the dialog (progn (princ (strcat "\n " dcl-filename " dialog not found.\n")) (exit) ; Exit if this doesn't work ) ) ;; Construct list of items (start_list "selections") ; Specify the name of the list box (mapcar 'add_list lstItems) ; Specify the AutoLISP list (end_list) ;; ;; (defun getItemSelection() (setq selectedItem (nth (atoi $value) lstItems) ) (if (equal 4 $reason) ; Then user double-clicked item. (done_dialog)) ) ;; ;; Confirms that user selected an item and that the item exists in list ;; (defun check_i() (if (member selectedItem lstItems) (progn (set_tile "error" "") T ) (progn (set_tile "error" "Please select an item.") nil ) ) ) (action_tile "selections" "(getItemselection)") (action_tile "accept" "(if (check_i)(done_dialog 1))") (action_tile "cancel" "(setq selectedItem nil)(done_dialog 0)(exit)") (start_dialog) ; Display the dialog box (unload_dialog dcl_id) ; Unload the DCL file (princ "\n") selectedItem ; Return this value. ) But as I understand this only allows one selection in the listbox, how can I allow multiple selections? And what are the $value $reason variables, is there an explanation about this somewhere? Quote
MSasu Posted April 13, 2010 Posted April 13, 2010 Please check this thread: http://www.cadtutor.net/forum/showthread.php?t=44639 Regards, Quote
Lee Mac Posted April 13, 2010 Posted April 13, 2010 mutiple_select = true; As for the $value etc, look at: Working with Programmable Dialog Boxes > Managing Dialog Boxes > Action Expressions and Callbacks In VLIDE help Quote
