Guest mature student Posted April 13, 2010 Posted April 13, 2010 (Revit 2010) I havn't graduated to stacked walls as yet, instead I've used the same cavity wall for below and above ground constrained to the relevant levels. Adding a plaster layer to the inside of the above ground wall was ok until I looked at the join in a section. Revit distributed the extra width equally to both sides of the wall. This of course meant that the masonry and cavities no longer lined up. Any thoughts on forcing Revit to distribute the extra width to the relevant side only? Many thanks for the reply to my last query (multiple copying). I should have looked at the 'Bar' a bit closer! Quote
profcad Posted April 13, 2010 Posted April 13, 2010 Have you tried to align the walls using the Align tool. Align the two masonry cavities. Quote
