Titles instead of number values in dynamic blocks
i have a window (on plan) dynamic block which has various actions, and attributes attached to it to extract information from to form schedules, question i'm asking is this; when i extend the cill to a pre-set depth, instead of a numeric value i.e 50mm (2"0), 100mm (4") etc showing up in the extracted data table, i want the extracted data to say stub, standard or extended, just wondered if this was possible and if so how?
i hope the is above is clear, many thanks in advance :)
Not without coding your own data extraction program.
When you get 2010 you will be able to make use of the new 'Block Table' parameter, which allows you to add your own column of information to a look up table.
Come to think of it, can you do that with a standard look up table?
