dumfatnhappy Posted August 23, 2008 Posted August 23, 2008 I'm laying alot of pipe and when I go to cut sections, some of the pipe comes in single line. I discovered that I was using different 'systems' not knowing. I go back and change the pipe to the proper 'system' no problem. How can I change the valves to a different 'system' as there is no prompt like when you click on a pipe? (pipe is double line and now the valves are still single which looks awful) Quote
