Hi
I hope someone has 5 minutes to help.
I am creating a set of sliding doors in dynamic blocks, I have figured out with some looking on the net how to make a 2 panel set of sliding doors in a dynamic block (aerial view) and how to keep the central point central in offset panels while the doors are stretched.
I need now to create a set of 3 panel, 4 panel sliding doors and a set of 4 panel centrally opening sliding doors.
Does anyone know where I can find help with this, a tutorial or a paper on the web?
Many thanks
The dynamic block white papers from Autodesk are a good start. What is it that you want the dynamic blocks to do? If you want to stretch an object equally in both directions, set your starting point to "mid point" and then add two stretch actions set to the same base point, but make sure that the action going the opposite directions is set to 180 degrees for angle offset.
Hi
Thank you for your reply, my 2 panel door is done in much the same way.
I need to know how to do it wthl 3 and 4 panels in a row.
Thanks again
Hi
Thanks again
I suppose you could have multiple stretch parameters, probably stretching out from each place where the doors overlap.
Hi Geependo....
I have had a quick play and i think your after something like this.... take a look at this block i have done for you... i have tried to keep it as basic as possible, let me know if its about what you want.
Kind Regards
DOORS.dwg
Hi Geependo....
Kind Regards
Many thanks its very close.
I have attached what I have done with a pair of doors (Offset pair) the black lines at each end are just where it locks into internal and external walls on plans.
I think from yours I maybe able to look up the propertys and use them to do what I need with my block.
Many thanks again for your help
Door Sliding01.dwg
No problems any questions ask... back in the office monday
  • 4 months later...
Hi Geependo....
Did you manage to achieve the 3 x offset panel sliding door dynamic block. I need to create the same thing and have also had some trouble.
kind regards:unsure:
