Hopinc Posted April 17, 2010 Posted April 17, 2010 Hi Guys, Does anyone know of a way of applying cross-hatching patterns within an Inventor 2010 drawing? I need to do this to illustrate depth of machining from a datum face. Obviously sections are cross-hached automatically but I can't see a way of applying hatching to boundaries within a drawing view? I am aware that a drawing view is just a projection from the model. I have used this hatching technique many times in AutoCAD format and I suppose I could do it there, but that seems to be a retrograde step and would of course lose connectivity with model changes. Thanks. Dave Quote
JD Mather Posted April 17, 2010 Posted April 17, 2010 Click on the view boundary. Hit s on the keyboard. Project Geometry the part boundary to hatch, then right mouse button Done. Add additional sketch lines to define boundary if needed. You can now add the hatch while in sketch mode from the Hatch tool. Click return to exit sketch. If you can't figure it out attach your file here. Quote
Hopinc Posted April 17, 2010 Author Posted April 17, 2010 Brilliant - Thanks a lot, I have just learnt something new. Regards. Dave Quote
vertical horizons Posted April 18, 2010 Posted April 18, 2010 ...Does anyone know of a way of applying cross-hatching patterns within an Inventor 2010 drawing?... While in an .IDW, I think you can adjust the hatchings there by clicking on the hatched portions of the view. You can also change the scale size of the hatchings, too. Quote
cbell1007 Posted July 30, 2013 Posted July 30, 2013 This was so helpful. thank you very much for posting. Click on the view boundary.Hit s on the keyboard. Project Geometry the part boundary to hatch, then right mouse button Done. Add additional sketch lines to define boundary if needed. You can now add the hatch while in sketch mode from the Hatch tool. Click return to exit sketch. If you can't figure it out attach your file here. Quote
geekster Posted December 1, 2014 Posted December 1, 2014 super helpful answer. This was my first google search on the matter and it took less than 15 seconds for the answer.. THank you sir! Click on the view boundary.Hit s on the keyboard. Project Geometry the part boundary to hatch, then right mouse button Done. Add additional sketch lines to define boundary if needed. You can now add the hatch while in sketch mode from the Hatch tool. Click return to exit sketch. If you can't figure it out attach your file here. Quote
