Wat is the function to copy one folder to another folder? and how?
Hi,
AFAIK there's no built in AutoLISP function to copy a folder, but you can use the "Scripting.FilesystemObject" ActiveX.
Here's an example, source and target arguments are strings (folders full pathes):
(defun CopyFolder (source target / fso)
 (vl-load-com)
 (setq FSO (vlax-create-object "Scripting.FilesystemObject"))
 (if (= -1 (vlax-invoke fso 'folderexists source))
   (vlax-invoke fso 'copyfolder source target)
 (vlax-release-object fso)
Hi,
 (vl-load-com)
Can you explain than what it is doing?
I'm not sure there is much more to explain - the code creates an instance of the FileSystemObject, and uses the CopyFolder method associated with that object.
Perhaps another way to do it, without using the FileSystemObject:
;; CopyFolder (Lee Mac)
;; Copies the contents of a folder (and subfolders).
;; Source  ~  [sTR] Source Directory e.g. "C:\\Directory"
;; Dest    ~  [sTR] Destination Directory (will be created if non-existent).
(defun CopyFolder (Source Dest)
 (vl-load-com)
 (vl-mkdir Dest)
 (mapcar
   (function
     (lambda ( file )
       (vl-file-copy
         (strcat Source "\\" file) (strcat Dest "\\" file))))
   (vl-directory-files Source nil 1))
 (mapcar
   (function
     (lambda ( directory )
       (CopyFolder
         (strcat Source "\\" directory) (strcat Dest "\\" directory))))
   (cddr (vl-directory-files Source nil -1))))
 (vl-load-com)
 (vl-mkdir Dest)
 (mapcar
   (function
     (lambda ( file )
       (vl-file-copy
 (mapcar
   (function
       (CopyFolder
Thanks for your effort.
This is i want.
This is i want.
You're welcome, but using the FileSystemObject is probably a lot faster.
This is i want.
I know very well and i am using always mapcar and lambda functions.
But you used "Function" inbetween mapcar and lambda. Can you explain wat it is doing there?
It notifies the interpreter that the lambda expression is to be treated as a function argument for the mapcar function. It has a slight performance improvement over using a quoted expression.
