Hi guys,
Sometime ago, I downloaded from a website a LISP called breakobjects18 written by Charles from www dot theswamp dot org
I love the LISP but have one small problem, the basic command is 'mybreak'.
Its a little long for my tastes and I was wondering if there was anyway to shorten it like how you would edit Autocad's aliases.
Thanks in advance!
:D
Hi,
You can rename the command. Search for (defun c:mybreak in the code and replace c:mybreak by c:mbr so that the command name would be mbr.
Another way is to define a new name (shortcut) adding a LISP expression at the end of the code:
(defun c:mbr () (c:mybreak))
Hi,
Thanks for the fast response!
will try that now :)
