Sketchup Help
Hello,
I see the object with texture in black color in the shaded with texture, face style. I only see the texture if zoom in, something like this:
ju47926310jju47926310jju47926310jju47926310j
http://yfrog.com/ju47926310j
Does any one can help me?
Thanks
Hmmm, never seen that before. Might be a graphics card issue. Try updating your graphic card drivers.
Thanks, well i work with the Sketchup for some years and never had happen this, this appears when i tryed to use the Indigo render pulgin, i had uninstalled the pulgin, reinstalled the Sketchup and the problem continues...
Thanks any way... :)
I would contact the guys at Indigo then. Maybe they have a help forum.
Thank you, maybe the problem it's with the file, i don't know if it was after use the indigo, but i have reinstalled the Sketchup and the problem continues, maybe them have an idea of what happens.
Thanks
A good way to check if it is indeed the file is to copy the content in that file, open a new session of SU and paste it there. Then see if the problem persists. In the past I have encountered some odd behavour with SU and this is the only way I seem to have fixed the problem.
Good luck.
Hello,
when you mean SU, you are talking about Skecth Up right? I'm from Portugal and never had heard that term ;). I have tryed to copy from one file to another and the problem continues, in fact the problem appears in others files but not all the files.
Thanks
Good luck.
Hello,
I solve the problem!!! In model info, Rendering, i had the anti-aliased textures clicked... that were the problem!
Thanks for all the help
Here is a image...
1ssemttulojkj
Good luck.
Aahh, simple. Glad you figured it out.
Yes I meant SketchUp when I said SU.
