hepcpltd Posted April 19, 2010 Share Posted April 19, 2010 Is there any autolisp by which line end can be stretched up to nearby text node as oer specified distance for filtering for selection set. Quote Link to comment Share on other sites More sharing options...
alanjt Posted April 19, 2010 Share Posted April 19, 2010 Not for an LT user. Quote Link to comment Share on other sites More sharing options...
hepcpltd Posted April 20, 2010 Author Share Posted April 20, 2010 Not for an LT user. I want to try with autocad 3D. Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted April 20, 2010 Share Posted April 20, 2010 I'm not sure what you are trying to do? Quote Link to comment Share on other sites More sharing options...
hepcpltd Posted April 20, 2010 Author Share Posted April 20, 2010 There are line and text objects in drawing in separate layer. It is a network type drawing and drawing should be such that each line end should connect with text node so that x-y coordinates will remain same for particular line and text. Is there any command/ autolisp routine to select lines and texts in selection box and user will specified max. distance (between line end and text) for auto connect of line end with nearby text. This will apply for entire selection sequentially. Quote Link to comment Share on other sites More sharing options...
alanjt Posted April 22, 2010 Share Posted April 22, 2010 Set Edgemode to 1, then select accordingly and extend. That's a pretty outlandish request. I've been wrong before, but I doubt something like that exists and it'd be pretty funky to try and automate such a task. Quote Link to comment Share on other sites More sharing options...
