Rectangular pattern, simple, error
Hi. Not quite sure why this pattern is failing or cannot be constructed. I want to pattern the hole (rectangular) in the direction of the sketch, starting at the hole's centre point, and I want say 10 holes equi-spanned across the sketched line (whatever length the line is). File attached. Thanks for your help.
Regards, David
CEA16626-2512.zip
it has something to do with your sketch and how it was referenced. I removed it as a reference for your hole, created the hole using linear references to the edges(37.5mm), then created a sketch after the hole creation for the path.
CEA16626-2512.zip
Thanks - understand what's going on ...
