Hello again all
I would like to extrude a small 2d bracket. When I enter the command, I'm asked for the height. I enter in .188
Then asked for angle of taper. This is just a strait up flat bracket, with 90* angles on the sides. Any idea what I should enter?
2000i seems less friendly for 3d.
You enter nothing since a taper is not required. This is what I get when I use the Extrude command.
Command: extrude
Current wire frame density: ISOLINES=4
Select objects to extrude: 1 found
Specify height of extrusion or [Direction/Path/Taper angle]: 12
The only way I'd be asked for a Taper angle is if I typed in the letter "T" for taper. Why should 2000i be any different?
Hi ReMark.
I tried it again with a new drawing I just did using polylines and it worked. I believe there is a command to change a drawing to polylines?
OK PEDIT. This worked out fine.
As always, thank-you for your help! Problem resolved!
