I have AutoCAD Architectural Desktop and need to remove it from my Desktop and add to my Laptop.
How do I do it?
Do I need to remove the Desktop version first?
Can I keep it on both. It is a fully licensed version.
Thank you:unsure:
Install on the laptop first (in case you run into a problem) then remove it from the desktop to be in compliance with the EULA unless you are on subscription.
Can you have AutoCAD on two machines if you have AutoCAD subscription.
I think we had subscription for this version of AutoCAD but it has since lapsed
I think we had subscription for this version of AutoCAD but it has since lapsed.
I'm sure the subscription is lapsed.
Why not just try to install '06 on your laptop? :unsure:
