Is there a way to come up with more colors than the options it gives you in the pull down?
At the bottom of the Color Control pulldown, you should have a Select Color option. I don't have Inventor but I think the colors options are pretty much an Autodesk standard across products, are they not?
That should give you access to all the index colors, a tru color full spectrum, and a couple of dozen color books.
At the bottom of list is Zinc Chromate. No option to choose color.
Whoo, like a chat room:shock:
Is that your overall color control or for a particular set of objects?
Like I said, I don't know Inventor. It must be different.
