I have a drawing of a NACA 0012 airfoil. I extruded it to length and would like to turn it into a solid. What are the steps to turn it in a solid?
You'll be doing this using Mech 2000?
So is this airfoil a surface or a mesh at the moment?
I brought the airfoil into AutoCAD 2010 (ignoring warning about missing proxy objects) and did a List command on it. I'm told the airfoil is already a 3Dsolid. There's nothing to do.
I have been trying to edit it by slicing but it won't let me.
Guess I will just have to dig a little deeper.
Thanks for your help
Yes using Mechanical Desktop 4
AutoCAD Mechanical is not Mechanical Desktop.
I was able to slice using an extruded spline. I did notice you had a couple of hatch objects within the solid. Perhaps you were inadvertently selecting the hatches and not the solid during your slice operation.
Shift + Space will allow you to cycle your selection if you did not know already.
KC
