Assembly into another assembly in inventor
Hello,
I need to know how to keep all degrees of freedom when importing or compiling an assembly from a host of other other assemblies (In Autodesk inventor 2010).
For example, I have a linkage mechanism assembly which rotates properly. When this linkage mechanism assembly is placed into another assembly, it doesn't rotate anymore!
Help will be appreciated, Thanks.
If you click on the properties(right click on the assembly name in the feature tree) you can change it to a flexible assembly. Flexible doesnt mean it will bend, but rather that the constraints will be kept.
