Hi, I've been trying to open this floorplan with autocad 2000LT, but I get the incompatible version message.
Can anybody help me out by converting this over or just simply open it up and identifying what program or update I need?
It's a factory floorplan that I need to furnish with machinery....
Thank you kindly!!!
(file deleted)
Innoteq 2010 draft.dwg
Go to AutoDesk and download "TRUE VIEW".. it'll permit you to save the file in different versions.
Thanks, but no go. Downloaded Trueview and the required trimmings (net framework 3.5) but I get the same response. Did my restarts and all.
Can anybody open this????
Once you have Trueview on your machine you should be able to view the drawing IN TRUEVIEW (not in Autocad yet).
To get it to open in your Autocad so that you can edit it you have to use the Trueview CONVERT option to change the file to a version that your Autocad can open; in your case rev2000.
Perfect! Beautiful! Awesome! Got it!
Thanks guys!
